    Dismiss Notice
Hot water tank runs empty too often. Any ideas? (PIC inside)
Discussion in 'Plumbing and Central Heating' started by New2DIYing, 11 Apr 2015.
  1. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Hi guys
    I have been living in my current house for a bit over 3 years now. The wife and I have both been working during this time and very occasionally had an issue where our hot water would run out (not run cold but just no water would come out the hot water tap).
    However my wife is no longer working and the strain of someone being at home all week is resulting in the hot water finishing on an almost daily basis. Again when it finishes the hot water taps stop producing water its not that the water is cold.
    My guess is that my hot water tank may be either too small or not functioning properly.
    I went up in the loft today and took some pictures:
    [​IMG]
    [​IMG]
    [​IMG]
    My understanding is the black tanks are for the central heating and the greenish colour tank is for the taps.
    Can anyone see an issue from these pictures?
    My thought is to replace the hot water tank with a new bigger tank?
    Thanks guys.
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    22,739
    Thanks Received:
    4,438
    Northumberland
    Country:
    One large loft tank to feed the copper cylinder, and one small tank to serve the central heating system.....
    Its the larger tank you need to attend to - either its too small or its filling mechanism needs attention.
    John :)
  4. JohnD
    JohnD
    15 Nov 2005
    70,967
    Thanks Received:
    4,019
    Crossgates
    Country:
    Cook Islands
    or maybe there is a drowned mouse blocking the exit pipe...
    • Thanks Thanks x 1
  5. RF Lighting
    RF Lighting
    31 Mar 2006
    19,993
    Thanks Received:
    1,354
    Leeds
    Country:
    Picture 1. Your big tank is wrapped in a black polythene insulation jacket and tied with yellow string.
    Check this is refilling when your taps are running. It sounds like the ball valve mechanism may not be working properly.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. Agile
    Agile
    26 Jun 2004
    63,801
    Thanks Received:
    4,554
    London
    Country:
    You need to measure the filling rate of the large tank.
    I am assuming that the black tank empties because it is filling at a slower rate than its being emptied.
    You should also check the flow rate of each hot tap and also consider how you could can use less hot water volume.
    Tony
  8. Nige F
    Nige F
    28 Jun 2005
    21,123
    Thanks Received:
    1,724
    Country:
    OR just change the float valve in the larger tank ( I never was good @ calcs.)
    • Thanks Thanks x 1
  9. Jackrae
    Jackrae
    20 Nov 2012
    2,187
    Thanks Received:
    366
    Dumfriesshire
    Country:
    It is also possible that your cold mains supply pressure has reduced possibly due to a burst mains. Does your kitchen cold tap run with a good flow, especially when you run out of hot water.
  10. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,310
    Thanks Received:
    1,888
    Hertfordshire
    Country:
    Turn the cylinder stat to 60 degrees and fit a new float valve.
    Andy
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
