During hot weather it seems that my cold water tank does not fill so eventually the taps run dry. I have to tap the side of the tank in the evening when it is cooler and then i hear the water starting to flow into the tank and then from the tank to the taps.
Does this mean a valve somewhere is expanding in the hot weather and sticking? Which valve is the likely culprit and where do i find it? This only happens is hot weather.
thanks very much
thanks very much
