HI
We have a four month old Hotpoint ultima and its started making the most horrendous din when spinning. If I put it on to spin empty it does not do it but with one dry t-shirt in it bangs like hell. It seems fine to rotate by hand and does not make a noise in normal cycle.
When I move the drum about it seems to have some limited up and down play in it as well as back and forth and the drum seems to run out of true on spin quite badly.
The only issue is my Mrs thinks a button off the boys tops is missing if this is stuck between the two drums would this cause the racket?
I dont want to go for the guarantee if its likely to be a self inflicted wound.
Cheers
Cheers
