Hi in this machine it was making a racket for a while and not taking the water to the chamber tank. Then it made 3 loud banging noises and stopped.
I took lid off . Belt was fine . Took side off and noticed water at bottom of impeller and the shaft it is on going to the motor was snapped into.
I've got a second hand motor but how do I get the old one out. I've took back panel off to take fan from rear. But there's like a plastic housing over the rear of the motor. Do I need to remove the drum to get it out . If so I think it will be worth it to replace all the bearing set .
Anyone removed the motor easily
Thanks in advance
Thanks in advance
