HOTPOINT CTD00 CONDENSOR DRYER
18 Jun 2011
Bradford
I HAVE A HOTPOINT CTD00 CONDENSOR DRYER THAT SEEMS TO STOP GOING AROUND AFTER 40 -60 MINS,IF I STOP AND OPEN THE DOOR AND WAIT A FEW MINUTES THEN IT STARTS AGAIN OK. DOES IT STOP WORKING IF IT GETS TOO HOT.
HAVE ALREADY TRIED A CAPICATOR BUT STILL SEEMS TO STOP,IS THERE A HEAT SENSOR.THE CLOTHES CAME OUT DRY BUT STOPED WOKING ABOUT 20 MINS LEFT,BUT SOUNDS LIKE A HUMMING NOISE WHEN STOPPED.
When it hums did u try to turn drum by hand to kick start it , wot uf cap did u fit to it
Tryed turning by hand but does nothing,try starting again straight away but just buzzes. Capacitor is from my own dryer that is the same as the one im fixing.
Open the door check the pin is attached to the door , then with a small screwdriver push the hole in at 12 0clock position does it start.
But did you try to start it with the door open and poke a screwdriver in the hole at the 12 clock position.
