Hotpoint DF61 fill problem?
16 Sep 2009
Glamorgan
I wonder if anyone can help me? My Hotpoint DF61 dish washer has started being quite noisy when filling. (only the last few weeks or so)
When filling the inlet solenoid switches on/off about twenty times (I've told you a million times about exaggerating!!) each time my pipes rattle (hence the noise), then it carries on with the cycle until it needs to fill again, more pipe rattling etc etc....
It is pumping and spaying and is generally cleaning the dishes well, it's just the noise,
I don't think there is any water leaking out so is it a problem with the level sensor perhaps?
Any help will be gratefully received......
sometimes turning down the pressure at the main water valve or at the dishwasher water feed valve under the sink can help
try moving the pipes to a different position
the inlet valve on the dishwasher is usually ok
try these and see how you get on
If you remove the left hand side panel and watch it fill you will see the float switch going up and down causing your problem.You need to clean the transfer hose from the water chamber to the filter and possibly the pressure chamber itself.
Thanks guys!!
having removed the side panel I can see loads of yucky stuff in the pipes, I think before removing this complicated lot (and the risk of subsequent leaks!) I'll try a cleaning solution, is there one to be recommended?
Mark.
The cleaning solution seems to have worked, no chattering valves this morning!
Thanks for your help!
