Thats right it's working your not used to it cos is prog to a diff model. It's surpossed to do that.
but since as though its programmed to wma22p it shouldn't do that should it?
the reason i say that is because when my original control was working it wasn't displaying lights like this..it use to first light program light > then active and then> door locked...
or is this how it spose to work now? if this is the way im not too bothered as long as its taking water from both pipes.
how do i check its taking water from hot? (bear in mind this control came from a machine with one pipe only cold).
cheers
