When my hotpoint wm52 fills with water, it trips the house rcd when the inlet valve stops the water coming in, when full. What can cause this problem? I tried all other functions after a bearing change, all works fine, but I didn't let the water fill the drum completely at this time, I just went through the basic functions, fill with water, wash, rinse, empty, spin. Then put on a load of washing, when the drum was full with water it tripped the house rcd. I had to remove the wet washing which lowered the water level. I was then able to reset the RCD switch on the machine and empty the water out. I then tried filling with waterwithout a load and the RCD tripped when the water fill shut off. Any assistance greatly appreciatede, thanks.
Big Rob 178
Big Rob 178
