In 2005 it was probably just white thermoplastic.I seem to remember you saying white twin and earth which may mean it is thermal setting not thermal plastic cable and thermal setting is rated 90°C not 70°C so reference method C for 2.5mm² is 33A table 4E2A.
Personally unless marked on the cable I would assume it to be thermal plastic and use BAS list but what I am pointing out your electrician could be correct without seeing how installed and having a bit of the cable to inspect or test I would certainly question 32A with 2.5mm² but would still accept it once shown it is thermal setting cable.
But even if it is thermosetting cable with a 90° rating, the accessories it's connected to won't like that temperature, so you're back to 70° and the current carrying capacities in the table I posted.
