I am moving into a brand new property next week. Due to a 6 month warranty clause, I cannot hang anything from the walls or fit any blinds! I don't want to put up net curtains on hooks as I HATE net curtains. What can I do with this awkward top bedroom window?
hi,for abit of privacy try an expanding pole used for showers,no screws or drilling,this will at least cover up to the 90 degree angles and very simply to install
Window treatment ideas for this kind of window are to not set the curtains to wide off the window. Probably only 15cm at most. Even though you have a lot of fabric to stack back when they open. You can use tie backs to hold them off the window. Another option is to use a thinner fabric.
Another thing that works well to give the window height is a valance or pelmet. Only rather than the usual 20cm depth make it 30 -35cm deep and fix it higher on the wall. So with the curtains not set to wide and a deeper top treatment this gives the illusion of a squarer window.
The dreaded arched windows!
Best window treatment ideas for arched windows. Most folks find this style of window a real pain.
It can be as simple or as complicated as you want to make it.
That seems like an unusual and unreasonable warranty clause. Does it actually mean what you think it does?
Everyone would be expected to have some curtains or suchlike for privacy, and therefore it may be so unreasonable as to be unenforceable, and thus invalid.
In any case, fixing something around this window should not affect any other part of the property, therefore would not invalidate a warranty in terms of the rest of the property
If you are ok with a needle and thread this would be a doddle.
fasten along the rake of the head as outlined in the picture in black some velcro either pin it or buy the one with sticky tape on one side. then buy a festoon type blind curtain and cut to the shape at the head affix the tape to the blind and fix as in drawing. remember that if you buy the blind deep enough to drop to the bottom then you can lower it at night for privacy. you can use any colour,the lilac is for representation only.
also please excuse my drawing paint workshop is not my forte
similar to wms's idea, you could probably get away with 2 x roman blinds.
bit of a pain to make from scratch (well, according to my missus they are anyway ) but both ikea and B&Q both sell cheap ones that can be altered to suit your size requirements easily enough
