How Do I Add A Radiator
8 Apr 2005
hi i want to add a radiator in my garage to my existing system, can i run from another radiator or should i tee in to the in feed and out flow 22mm and could you tell me where the flows are best located..cheers. :?:
Thanks a lot for a quick response Kevplumb :) If i come from above down to the rad should i take 22mm as close to the rad as poss or can i use 15mm straight to flow and return.. :?
kevplumb said:
tee into the flow and return :wink:
Flow and returns usually located under upstairs floorboards.
Run your new feed from them to your new rad.
You can tee off another rad if it is fed from a single 15 mm feed branch off the F & R and your system is up to it. :D
thanks alot guys great help :lol:
I should think this would be the same building regulations as the conversatory where the radiator must be controllable.(?)
Well spotted by Masona.
You should fit isolating valves so that they can be turned off before they exit into very cold places.
Comes under energy conservation.
BCOs will cut your legs off if they inspect your job :D
Even if the garage is being converted to a reception room whith a through room in to the lounge :?:
If you are involving BCOs with your conversion, ask them for advice on whether the isolators will be needed.
Probably not but worth asking anyway :D
