Connect all the RED cores together into 1st terminal
Connect all the EARTH cores together into 2nd terminal
Connect the two BLACKs that DO NOT have a red sleeve to the 3rd terminal
Connect the single BLACK with RED SLEEVE to the fourth terminal
Connect your downlight between the 3rd and 4th terminals - ie between the red sleeved black and the pair of blacks. If it is a metal fitting, connect the earth to the earths.
I am sorry Telly, but if you did not know what that was, then you have no business messing around with electrics. Call someone in who knows what they are doing, before you kill yourself or somebody else.
Au Contrare - I suspect he knew the function of it, but not the name. Knowing its function, he would have been able to apply some logic to what to do with it. Obviously he didn't so came here!
