How do I reset my boiler
14 Apr 2004
I have a suprima 50 L by potterton
I have been away for 2 weeks and found the gas supply had been turned off.
I have turned the gas back on but the pilot light is not showing and the boiler does nothing when I switch the heating on
I think I need to reset it but not sure how as i have no instruction manual.
any ideas??
Gibby
That boiler does NOT have a permanent pilot !!!
If it has electronically tripped then you push the button marked ( surprisingly ! ) "reset" on the control panel below the knob.
thanks
the red light is flashing but when I press the reset button it does nothing
I have tried holding it down for a few seconds but it just keeps flashing
any other ideas??
ta
G
Disconnect power for three minutes and see if it resets after that.
If not start saving up in case you need a new PCB !!!
its now working
thanks for your advice - worked a treat
thanks
G
please note forum rule 7
