How do you cut Perspex?
12 Jan 2006
Afternoon all
My father needs to cut some perspex and would like to know what is the best way to go about it e.g what tools etc are needed e.g a scriber etc? could somebody please give me some idea on this or suggest any suitable website etc?
Many thanks
Hi! I have always scored the perspex with a scriber then snapped it over( and close to) a straight edge like a table or workbench.
alpem
Like Alpem I've cut it by scoring (quite deep on both sides ) then putting it on the edge of a bench or table (and putting a straight edge plank of wood on top - plus a bloke standing on it for big 4 to 6 foot lengths!) then, wearing gloves and using both hands, a very quick, confident, snap downwards, breaking off the smaller piece. Ta .ra!
For smaller pieces it is always still better to have a helper holding a piece of straight edge wood on top. Never tried the angle grinder method as I didn't have one then but I can see it working. Does it melt it's way through? . Jigsaws, hacksaws etc etc just break things up all over the place and waste material. good luck!!
Use a straight piece of timber to provide you with a straight edge to cut to.
Make sure that you are putting the timber over the piece that you want to use in case your blade "skates" causing a scratch over the piece you want to use. I just kept running down the line with a stanley blade (make sure its a sharp one) until I cut right through.
OK Everybody,
Thanks V much indeed for everyones help!
CA - depends on the type of cut (straight or curved), the thickness of acrylic and range of tools/equipment available.
Straight cut = table saw with tipped negative rake teeth, say 96 for a 300 dia blade; bandsaw with fine toothed blade, maybe 6tpi skip; handsaws - panel @ 11+tpi, tenon @ 14tpi ... the thinner the material the more teeth; score BUT ONLY for small widths, large bits you run the risk of shatter. Support with battens.
Curves = bandsaw, jigsaw (acrylic blade - fine), coping saw.
Finishing = straight, you can use a smoothing plane (thin stuff sandwich between timber), glasspaper, then buff. Finish off with Brasso.
To join acrylic use Tensol cement.
