How do you fit a bath panel?
2 Feb 2013
Aberdeen
For a straight front bath panel, it's quite easy: measure and cuto size, then slip the top of the panel under the lip of the bath, screw the bottom of the panel to a batten...
But what happens if you have pipes at one end of the bath? you can't really place the panel in front of the bath then slip the top under the lip as the pipes (incl waste pipe) get in the way. You can't slide it sideways either because there is not enough space on the side and the bath also has a lip at its other end.
Any advice?
The template will only help to cut the panel to fit around the pipes, it won't help to put the panel into position?
