I have a high gloss bath panel to fit to my new Whirlpool bath.This is the sort that comes in two pieces,one that is a chamfered around each edge panel and the other looks like a piece of plinth.
The height is supposed to be adjustable from 400mm to 550mm with three screws put though the plinth into the panel from behind.
The problem is I can`t quite see how this will fit to the bath,it doesn`t fit under the lip and doesn`t fit length wise because of the square panel edge and the curved edge in the corners under the lip.
Surely you haven`t got to cut away the finish on the MDF.
What is the correct proceedure to correctly fit one of these panels and how would it be secured at the top edge of the bath?
