- Joined
- 22 Jan 2007
- Messages
- 22,905
- Reaction score
- 3,072
- Country
It is undoubtedly a connecting to the main pipework feeding something else.The grey plastic pipe mystery still remains.
Do you have a feed/expansion tank for the heating (primary) circuit? That would have a vent pipe over the tank. The one over the storage tank more likely from the DHW cylinder (secondary circuit) (assuming you have one).
Just noticed the other thread on this subject
None of the pics show where the grey plastic pipe goes, so can't comment on that. I assume the copper pipe over the far corner is the vent pipe from the DHW cylinder.
By Type 2, do you mean this? Screwfix website calls it Part 2.
That type is better than your Part 1 valve, less chance of sticking due to scale round the plunger, but I'm not sure I'd bother replacing it now you seem to have solved the problem, without even replacing the washer. It will be threaded 1/2" BSPM like the existing. More usual to use a tap fitting (straight or elbow), doubt if it has a taper for an olive, but you can use a female threaded fitting like the existing, with PTFE tape.
I can't see why a tee and upstand has been used, maybe the guy had a tee and a bit of pipe to hand, but no elbow!
No, the body is in one piece, as several posters have said, and you can see from your pics. The only dismantling you can do is what I suggested in #22, either in situ or after removing it.Is there any possibility that the old float valve in the water tank could be undone, and detached from its own fitting
You can use them to remove the valve. Need to loosen the back nut first, which might be a bit tricky as it is rather shallow. A well-fitting open-end spanner could be the best bet. And do it as robinbanks said in #23, to avoid putting force on the tank wall.Now I have got big Bahco spanners and Pipe Wrenches, and can attack the old float valve trying to undo it
Just use large enough grips. On a scale of difficult plumbing jobs this one is pretty low down.Is there any chemical that could loosen the frozen up bolt with the adhesive?
I have to say that I can't see any rotting or rusting that's apparent on that, the nut has a bit of a coating but nothing to be concerned aboutClose inspection on the photos reveal the copper pipe is in bad shape showing the signs of rotting and rusting.
