Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have set a plasterboard section approximately 6mm under flush to the old wall is this too far or just right for 2 coats of skim? View media item 95284
It would be easier to pack out the plasterboard
to the level of the old plaster.
Tape the joint ,then feather the skimming about
a foot into the old plaster .
It should be that the cornerbead above the door lines up flush with old wall so so what ever option you take make sure you have a bead handy to see how it sits at the moment its way off
