How long is clean water in CH safe before adding inhibitor
7 Jan 2010
Yorkshire
I've been doing some work on my Central Heating system for a couple of weeks now. Started 2 weeks ago with a full drain down, removed some radiators and re-routed some pipes, then refilled as replacement radiators hadn't arrived on time. A week later (the weekend just gone) partially drained down and installed 2 new bedroom radiators, connecting them upto new 15mm pipes.
I have just ordered a new downstairs hall radiator, which won't be delivered until next week, just before we go on holiday for 10 days, so I won't be able to fit that for nearly 3 weeks from today.
I'm now wondering if I should put some Fernox F1 protector into the CH system, but this would only be in for 3 weeks as I would then need to perform a full drain down to fit the new downstairs radiator as the pipes will need to be adjusted.
Given that the system currently only has clean water in it, is it safe to leave it running with this water for a further 3 weeks or is that likely to start causing issues and I should add inhibitor now and then again after the downstairs radiator has been installed?
The system is 28 years old. Before I drained the system down a couple of weeks ago, I checked the Adey Magnaclean pro 2 and there was barely anything in it. I then added a dose (500ml) of Fernox Power Cleaner F8 and ran the heating for a couple of days (on and off), then drained it down completely before filling up with clean water. To my surprise, the magnaclean was still showing hardly anything. This clean water was then partially drained out over the weekend and I will be doing one more full drain down and refresh.
I would appreciate your thoughts on the use of F1 inhibitor? Is 3 weeks running without it likely to start causing issues or is it best to be safe and put some in.
Having just read some forum posts where people are saying they have been running their CH systems for years without inhibitor and without issues, it would appear my question is probably moot and 3 weeks without inhibitor is very unlikely to cause any problems!
As usual, I'm probably over thinking it :giggle:
18 years+
Yes your overthinking it :)
Do it when your completely finished.
I'd say you certainly are overthinking it, I have a 50 year old open vented system with some rads over 40 years old and the system occasionally gets the dregs of any inhibitor I've left over from my relatives systems that I look after.
