.....before I can simply glance at a bare CPC and automatically cut a piece of sleeving that matches perfectly every time?
It will take for ever - Mr Murphy and his Law guarantees that the first attempt will nearly always be fractionally too short. The clever ones probably start with the CPC slightly too long, and then adjust accordingly.....before I can simply glance at a bare CPC and automatically cut a piece of sleeving that matches perfectly every time?
To pick up the cutters from the floor, what other reason is there ?Me too, but I don't understand why you feel the need to bend over
Seriously, though, what I usually do is slide the uncut sleeving over the CPC until it is short of the far end by the amount I want to leave exposed, then bend over and cut the sleeving off where the end of the CPC is.
Do yours make a noise when you do that?To pick up the cutters from the floor, what other reason is there ?
Yes, it would be.Much more expensive?
