    Dismiss Notice
How many 10Kg Easi Fill bags
Discussion in 'Plastering and Rendering' started by Richyfenn, 16 Dec 2017.
  1. Richyfenn
    Richyfenn
    25 Aug 2011
    7
    Thanks Received:
    Kent
    Country:
    Roughly how much Easi Fill would I need to joint and fill 4 or 5 tapered joints between boards (2.4m length)? How far does one 10Kg bag go? I can't find any clues.
    Thank you
    Rich
  2. roughcaster
    roughcaster
    2 Aug 2007
    4,732
    Thanks Received:
    631
    Moray
    Country:
    Even one, 10kg bag would be too much, so there's yer answer.
  3. Sponsored Links
  4. Richyfenn
    Richyfenn
    25 Aug 2011
    7
    Thanks Received:
    Kent
    Country:
    Perfect! Thank you!
  5. opps
    opps
    16 Jun 2006
    4,649
    Thanks Received:
    731
    London
    Country:
    Just be aware that it will need two hits. In my experience, the first fill will have lots of air bubbles that will need a second hit.
    I use it for the sake of convenience (in general decorating) but it is very soft and there are many times when I use harder fillers. That said, you asked a specific question and the reply that you got seems to be fairly sound. Apologies for hijacking. I just want to make sure that others realise that it isn't some kind of universal filler (it shouldn't be used on woodwork for example).
  6. Sponsored Links
  7. Happyplumber
    Happyplumber
    9 Feb 2009
    4,237
    Thanks Received:
    1,008
    Berkshire
    Country:
    Use joint filler on your first coat for any drylining and then finish off with easi fill
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
