how much does a full bath of water weigh?
2scoops0406
And if you really want to waste a few brain cells, our favourite mad scientist puts a half-filled glass of water on the scales. He then dips his finger in it without touching any part of the glass (Don't ask why). Do the scales read more, less or the same?
Same.
15 Nov 2005
Gloucester
Cook Islands
more
by the weight of the volume of liquid that he has displaced with his prodder
21 Oct 2004
You don't need to add the weight of the bather to the weight of water.
The bather will displace his own weight of water
No you won't you will displace your own volume of water.
You're both wrong.
Ignoring, for now, the scenario of the bath overflowing, the volume of water displaced by a buoyant object has the same weight as the object. The bath is then supporting the weight of the water and the weight of the floating object.
2
2scoops0406
You're both wrong.
Wrong, how can it not overflow? the bath is full.[/quote]
Who mentioned anything about bouyancy?
2
2scoops0406
more
Wrong, indeed if the glass was full, and the resulting water displaced ran off the scales then the weight would go down.
The fact that you have stuck you digit into a glass of water, has no effect as there is no additional force exerted onto the scales. weight of course being mass x acceleration. (there is no acceleration unless you cut you finger off).
You could do the same with an olympic swimming pool and a 1000 tonne weight suspended from a crane, there would be no increase in weight of the swimming pool. (as long as the crane is not in the pool!)
Kes
31 May 2006
Worcestershire
more
The question clearly stated a half-filled glass, and the finger not touching the glass. So, discounting a hugely fat finger, the glass cannot overflow.
There will always be gravitational pull.
So, if you had some sort of strain gauge on the crane, it would not change as the weight was lowered into the water? What if your 1000 t weight was the same density as water? What if your 1000 t weight was a boat?
Kes
31 May 2006
Worcestershire
Should it not be 'the volume of water displaced by any object has the same weight as the object', irrespective of whether the object floats or sinks?
2
2scoops0406
Apologies, then the answer is that it'll weigh the same.
Which will experience an equal and opposite reaction by dint of being hopefully attached to your hand.
It would "change" weight
