Hi all
A little background: a couple of years ago a plumber fitted a rad in our garage conversion but for whatever reason he put it on the back wall. However it's the front half of the room that is coldest as it juts out from the house, and the walls in this 6 foot or so of the room are thinner than the other walls. Also, the window is I suspect too big for the size of the room (7 ft wide), and despite being uPVC the draught coming off it almost cuts your head off when sitting on the sofa under the window.
Anyway, I was thinking of removing the existing rad and putting a long (e.g. 2200mm) rad under the window. If we kept the sofa up against the rad, I was wondering how much it would affect the heat output of the radiator? i.e. how much heat is radiated from the front of the rad and how much convects up out of the top (assuming I go for a P+ or K2)?
And one last question: the pipes feeding the existing rad come straight down from the ceiling (it was plumbed in under the floor in the bedroom above). If I extend these pipes by another 15ft along the skirting of the garage conversion to the window wall, is it likely to affect the CH system in any way, e.g. flow or anything else?
Thanks in advance
Andy
Thanks in advance
Andy
