Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I'm looking to get my bath changed for a new one, its just s swap nothing else needs to be don, how much should I expect to get charged over all? Ill buythe bath its just the install? [/code]
I did one recently and it took over three days in the end. But then I did have to replace the entire floor and three joists.
If you are lucky enough to get away with a swap and nothing else, I would charge £96.00 for labour. But that is Cumbria, I suspect you would be looking at a bit more.
A 'blind' quote maybe?
There's no such thing as a direct replacement - the drains won't match up, and neither will the taps unless they are on flexi's....
Then there's making good to the tiling, bath panel, shower screen.....the list goes on.
John
John
John
I agree with you completely mate, but when people suggest that it is 'old one out, identical new one in' I need to see for myself....never found one yet!
John
When the OP lets it be known locally of a job where he knows exactly what needs to be done, how long it will take, with goods supplied by himself, priced by a bunch of strangers on the web who haven't seen the job, the stick will be handy to beat off the the hordes of plumbers scrambling at the door.
