Hey Folks!
I am about to fit a new fibreglass roof and i've got the whole sequence down except this one piece.
I've fitted lead flashings before and understand how they go in, but I'm looking at these fibreglass replacements and i'm filled with trepidation. I'm hoping someone can put me out of my misery!
These are the badboys in question
https://www.selcobw.com/c100-simulated-lead-flashing
Naturally the wall mortar needs to be chased out as normal in order to receive the tongue. Does that folded over section really hold it in strongly enough?
What exactly are you meant to use to hold the things in place given that there isn't a traditional bung? Does that folded over section really hold it in strongly enough?
I assume the overlap is similar to standard lead (4in or so), but doesn't one section of that folded over bit get right in the way when you're trying to fit them over eachother?
I also notice that it say 'can be bonded using GRP trim adhesive' - do they mean the overlapping edges then? or do they mean shove it in underneath to bond it to the wall?
Is it old fashioned sand and cement to fill up once they're in?
I'd really appreciate any insight you guys might have on this!
Cheers
Cheers
