Thanks for the replies everyone. To clarify again, I have done this before and I know how to sand a floor. I've done this a number of times and in this specific instance I am looking to completely remove the varnish.
I understand that you can key a varnish floor to re-coat. Not sure if this would have worked well in this case as there were a lot and some very deep scratches, but regardless I have completely removed and applied a wax oil finish in the other rooms so it makes sense that I do the same in this one. I personally find it to be a more forgiving and natural finish than the varnish.
I've successfully used a hired upright drum sander and a DIY level belt sander in the past and they both have their pros and cons. My question was really only to ask people who have done this before about their opinions on what size of room is big enough to make it worth hiring an upright, drum type sander as I was swithering on this. Obviously if it was a 1x1m cupboard I'd just be using the belt sander and if it was a 4x6m open room I'd be hiring, but there is a tipping point somewhere in between.
My memory of using the upright was that it was fine on the long straight sections, but I spent more time on all of the edges and recesses and it took off a lot more wood. When I used the belt sander I could get in nearly everywhere, better control, less wood removal, but a hellish slog in the bigger sections.
