sanding floorboards without industrial floor sander.
29 Dec 2005
London
I recently hires an industrial floor sander to sand my living room floorboads to great effect.
I now plan to sand my hall boards but I will be unable to use the same hired sander because my hall is 3 ft wide and the boards run across the hall.
If I have enough time, is it possible to sand the floorboards with a smaller domestic belt sander or orbital sander? If so, which will would be best?
The boards are level because they are new, so I don't need to take too much off the top to give a flat surface.
Any suggestions would be really helpful.
Thanks,
Matt
belt sander is the way to go, are they screwed down? Might be easier taking them up one by one and doing them on a workbench.
Matty - hire a 4" belt sander (something like a Makita) and unless your hall is 30' long shouldn't take too much time or effort, especially as your boards are new/clean. A cheapo sander from a DIY shed might do the job if the hall is miniscule and you'll probably burn it out; hire a decent one for less.
