Hi All,
Getting ready to start renovating my bathroom as it's the last room in the house to be done before we move in.
The main problem is that when I've removed the old tiles (that were all wonky/uneven), it's pulled a fair bit of the original plaster off. I can see the plaster/cement has essentially broken down to sand again. The end wall where the door/shower is located is worse and goes back to the original blockwork.
The adjacent wall along where the bath will sit is a little better but I'm sure when I remove the old tile adhesive then a lot of that will come away too.
Here's a pic of the end wall
And you can see here how its easily pulling away
And what it pulls away
Here's the other wall in question
So questions are, whats the best way to approach sorting this out? I'm pretty sure most of the end wall will end up being taken back to the blockwork including the section over the door.
I was thinking of lining that wall with some hardibacker boards, tank it and then tile on top.
The other wall may just need spot repairs where the worst sections are. What would be the best product to use to do that so that its ok to tile onto again?
Or would it be best to board out that section as well with hardibacker?
Is some kind of cement board the best option or would it be better to get a plasterer in to sort before tiling?
Cheers all!
Andy
Cheers all!
Andy
