C
Coniferman
This is probably Mickey Mouse but I have already bought one "wrong part" so hopefully someone can tell me what I need.
I bought a new basket strainer. It is not as deep as the old one as it does not have overflow or pop-up. The old one had both but not used.
The new one looks like this:
http://cgi.ebay.co.uk/KITCHEN-SINK-..._Plumbing_MJ&hash=item56446ef953#ht_615wt_698
It will connect to a u-bend which has an outside thread. The outer diameter (above the thread) is measured as 50mm.
With the strainer in place the gap between the bottom of the strainer and the top of the ubend is 90mm. (give or take a washer)
I don't know if this is a standard requirement and someone can tell me what I need???
What the old system had was a piece of tube (40mm outer diameter) with a groove 6mm from the top. A plastic nut pulled the groove up to connect to the basket and a 2nd nut had a rubber washer to connect to the u-bend.
I guess one solution would be a longer 40mm tube with the groove. An additional problem is the nut that connected to the old strainer is too tall. There are less threads on the new one so it wont go all the way.
I have THAT diy warehouse not far away.
