We have a new Delta close-coupled toilet (Bathstore.com) which has a plastic male-threaded fitting on the bottom of the inlet valve. What is the correct way to connect this to the copper 15mm cold water supply? The installation instructions appear to have been translated from the original Chinese (probably by Super Mario!
) and offer no clues.
The thread appears to accept the nut of a 15mm compression fitting (without the olive) but this wouldn't give a watertight seal. Are you supposed to use a tap connector? All the ones on the Screwfix site seem to be metric one end and imperial the other.
Is it OK to use a metal nut on plastic or should I be looking for a plastic fitting?
