How to connect two TVs to a PS3
I would rather buy one from a shop instead of ebay. If you do have problems with it not working you will have no problems sending it back..
John..
That's true. Also I would make a best offer well below £18 so as to be clear of import duty. :wink:
The expensive option: AV Amp. I have 2 HDMI going into my AV Amp, and one HDMI out to my TV. AV Amp is only really worth considering if you have a semi decent home cinema set up, and/or lots of devices to plug in and manage.
Yes but I need to service two screens!! That requires two HDMI outs. :D
A av amp is no use unless it has 2 hdmi outs. These start from about £700.
John
you should try shopping around, there are plenty for less than £700, with enough output options to satisfy all but hardcore AV freaks
Lots of cheap amps have 2,3 or 4 hdmi inputs. For a amp with 2 hdmi outputs you are looking to pay at least £700. A Marantz 6004 has 2 hdmi outs it's around £799, there is also the Yamaha 2065 which you might find cheaper.
John..
