How to dismantle cast iron spiral staircase spindle and rail
30 Mar 2011
Devon
Hi. I'm trying to dismantle a cast iron spiral staircase and I'm not sure how to detach the spindles from the rail. There seems to be holes in the rail and a spike on the end of the spindles. The spike goes through the hole and it seems to have then been welded so the hole is not visible from the top of the handle rail.
Please see the attached picture of my rail
http://www.diynot.com/network/benners/albums/
and the link below shows the same staircase as mine dismantled so I know how it can come apart.
http://www.ukarchitecturalantiques.com/stockimages/3783_2.jpg
Any assistance on how I detach the spindles from the rail would be much appreciated.
Thanks!
I believe the nuts on the underside of the spindles need to be removed first.
This will allow the spindles to unscrew from the handrail by twisting them.
Once the handrail is loose it can be lifted off allowing the spindles to be removed.
Thanks for your suggestion. The bolts have been removed but the spindles don't screw into the hand rail they just have a spike on the end which fits into a hole in the rail which seems to be welded in place. I've tried turning them but they don't seem to want to budge and I don't want to force it.
Would heating it up with a blow torch help? Does anyone have any experience of this?
