How to dress a boiler?
26 Jul 2013
Surrey
OK, just had my combi installed, woo hoo!!
Basically now I have a cupboard and piece of work surface to fit where the old boiler was below.
The boiler obviously has a lot of visible copper pipes and I was just wondering what people actually do with them?
Do you box them in or leave them out?
Anything you want but...
1- keep to the stated clearances
2- If boxed in completely make it removable as makes services easier
3- If boxing the flue in it needs inspection hatches at every joint
Kitchen unit is the normal
Hi
To cover the pipes-
Fit the work surface. Tile walls to the pipes. Make a box section from worktop to bottom of boiler with enough clearance to remove. Tile box section with grout lines as wallgrout lines. Mastic to wall tiles.
Cover the pipes with ply and tiles, make sure that all the screw heads are completely mullered and that the tiles are end of range and cannot be matched, the tile adhesive has to ensure that the tiles will only come off in very small fragments or 10 fall off at the same time there is no inbetween,
finally practise the blank look when the words "access panel" or "access will be required " are spoken to you and be ready to complain how long the jobs taken/mess being made. be lucky :D
Phew. I was worried for a while that it was just me. Now I know that there are others.
We should form a support group. :D
Hmm sounds like I am going to have to be creative making something that can be removed yet looks like it can't lol
Just a quick question... the boiler people put the pipes over existing tiles... it this normal procedure or should the tiles have been removed before installation?
Normal procedure, unless the customer specifies otherwise when getting a quote.
Ignore the first three responses and do the opposite.
congrats, you are now a fully fledged Pro Kitchen Fitter. :roll:
DH
Oh thats great!! I was hoping it was usual procedure but had a pang of "have they taken a short cut!". I'm sure they've done everything as they should!!
Removing tiles, chasing in pipework, making tiling good would make quite a difference to the price.
Yeah it doesnt bother me really. The only slight concern I have is what happens if I want to change the tiling in the future...
