How to fill 1" gap between door frame and lintel
20 Sep 2021
hi guys
I will be cutting opening in the garage and fitting personnel doors. It seems I will end up with a 1" gap between the door frame and lintel. Whats the best way to fill it? Simply fill it with mortar or is there a smarter way? I know there are infill panels available but it seems overkill as they're mostly for much larger gaps.
thanks
is it wood or plastic frame/door??
would raising the door a bit reduce the gap in a practical way ??
doors between garage and dwelling need a 100mm threshold as a barrier against flammable liquids and fire
It’s metal. Doors are between garage and garden so no need for additional threshold although it’s already about 100mm above ground from the garden side. I could fill the gap with wood planks as I have plenty but door frame is only bolted on the sides so the gap above needs filling only for visual purposes
You could screw your timber to the frame before install, or just foam it.
1 inch steel u channel welded on top of door frame, painted same colour as door it should look as if it's part of the original door
