We've just had our loft converted including adding a new shower room. I'm supposed to be doing the tiling which I've done before with no problems so thought this would be no trouble either but now I'm stumped! Basically, we bought the shower tray before the plastering was done so got what we thought would be the correct size to fit the alcove (on the advice of the builder), but turns out it was a little too wide so the plumber had to gouge out all the plaster along the bottom of the wall to get the shower tray in. So now we have an area at the bottom of both side walls that will need to be filled somehow before tiling & I'm not sure of the best way to do this. Each gap is about 1cm deep, 2cm high & 70cm long.
I was thinking just polyfiller but it's a fairly large gap for that. Also given that it's at the bottom of the shower I was wondering if I should go for something waterproof to help minimise the risk of leaks? Is there a specialist product for this kind of thing? Or could I even just use the tile adhesive or grout as a filler???
A bit of googling on this has worried me as I keep finding info about how you should be waterproofing the entire area behind the tiles in a shower (e.g. using special plasterboard or tanking) which hasn't been done, it's just ordinary plasterboard & plaster as far as I'm aware. The builder (who seems to be a very competent & experienced bloke and has completed the conversion to a high standard) knew this alcove would be a shower so I've trusted him to do it correctly but now I'm a bit concerned it's not been done right... feel a bit like I've opened a can of worms looking for a solution to what I thought was a simple problem!!
