Hello,
Without boring you with the details, the wardrobe door got wrenched off its hinges, and a couple of the holes that the fitting screws into (on the wardrobe itself) are a bit broken.
I can't just use a thicker screw, because the screws are pretty thick diameter already (5 or 6mm), and the screw goes through the fitting and into the wood so can't be any wider. And I don't have any longer screw of the samem diameter.
Pretty poor explanation I know...but the screw hole is probably now 7 or 8 mm, for a screw a couple of mm smaller.
What can I do to remedy this?
ta
ta
