How to identify a leak
26 Sep 2004
Manchester
So regular double-glazed bay bedroom window. Certainly over 10 years old.
It's leaking. Even allowing for condensation, we get a lot of water on the bottom sill.
Any tricks to identify the source would be gratefully received so I can decide what to do. Clearly it could be between wall & window frame; or frame & opening windows, or in the panes ie PVC/glass. (The seals all seem fine by the way - all clear).
Please don't suggest pouring coloured liquid in as it is on the first floor ! That's what I would do if ground floor.
Here's hoping for a trick of the trade. Thanks in advance.
Hose window from outside whilst someone check the inside...seemples
if the drain holes inside the frame are blocked water can backtrack from allsorts of places, if the cill isnt level ie: runs back, it can send water towards the internal cill. simply if the sealant has given up outside, rainwater can find its way inside. etc. etc.
