Hi there,
I'm using porcelain tiles in the garden. It's quite a 'wet' garden due to run off from the neighbours land so I want to ensure that my tiles are properly primed (I've read that it's crucial with porcelain tiles).
I also read that you can use SBR and cement to make a slurry and just 'paint' it on to the tile.
Is the following SBR and cement suitable?
Everbuild SBR 503 - https://www.amazon.co.uk/dp/B001V9X..._dp_93Z3YHZGYEV7NJWDM4WY?_encoding=UTF8&psc=1
Blue Circle multi purpose cement -
https://www.diy.com/departments/blu...f3QAqcaAs7qEALw_wcB&gclsrc=aw.ds&storeId=1377
And, if so, my next question is - what is the correct mix to make the slurry?
I've read 1 part SBR to 1 part water to 4 parts cement? Is that correct?
Other things I've read say not to use water and just use 1 part SBR to x parts cement?
Anyone got a definitive answer for this?
And... last question that I can't seem to find the answer to.... can I just slurry loads of tiles and leave them for another day before laying them? Or do I need to lay them when the slurry is still wet?? Or - after an hour? Or when the slurry is sticky or whatever?
Thanks for all your help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
