How to move a washing machine down 2 flights of stairs
2 Jun 2010
Hi
Firstly apologies if this is the wrong section to post this query in
I am moving in one week and am a little worried about how to get the washing machine out of our 2nd floor flat. Been doing some research and looks like the best idea is to use a stair climbing trolley and with 3 people I am hoping if we go slowly we will be able to get it down the stairs. Thing is the only trolley I can see to rent is with a safe working load of 50k now I am guessing washing machine weighs around 70k ish the guy in the shop told me it will still be ok but still a bit concerned it is not going to support the load.
If anybody has done this before and has good advice I would really appreciate it. I saw one comment on the net about trying to remove the concrete ballast blocks but not sure how easy this is to do and also how to get them back on etc
Austin
Hi
Austin
Depends which make & model, but often just 2 bolts fixing it to the base of the drum assy & simple to remove by laying the machine on its' back. Although, if you have it strapped to a stair climing trolley I would not think you would have a problem leaving it in. I would have thought that they would be ok with a much higher than the recommended load. But obviously it's your decision, I've never tried it personally
About the only thing you will gain by taking off the balance weight is extra work. Unless you have a Miele professional that weighs 100+kg I wouldn't worry too much. Get a climber with integral strap or use a ratchet strap as jj mentions. Anyhow going downstairs isn't that bad...you have gravity on your side. Its much worse dragging the thing up 2 flights. The 50kg SWL climber they offered you is probably tested at min 50% overload before the certificate was even issued.
