    Dismiss Notice
How to put leak sealant in via Magna Clean?
Discussion in 'Plumbing and Central Heating' started by theluckiest, 16 May 2017.
  1. theluckiest
    theluckiest
    16 May 2017
    2
    Thanks Received:
    Country:
    A plumber fitted a Magna Clean for us recently and we now want to put leak sealant through the system (rather than fork out hundreds to pull all of our floors up to find a leak we have).
    Can anyone explain the process to us? I.e. do we need to drain water out before putting the leak sealant in?
    Thanks in advance.
  2. ianmcd
    ianmcd
    15 Aug 2010
    15,288
    Thanks Received:
    5,360
    Lanarkshire
    Country:
    what boiler do you have ?leak sealer can damage most modern boilers and I wouldnt advise you use it on a modern boiler, good chance it will invalidate any warranty you have if it is a modern boiler
  3. theluckiest
    theluckiest
    16 May 2017
    2
    Thanks Received:
    Country:
    The boiler that we have is a Valiant Thermocompact - the warranty for it expired long ago...Thanks for the reply!
  4. Why the need for the leak sealer? It can be put in via the magna clean though; you'd turn off both valves, undo and empty it, put the sealer in, and then refit it.
  5. ianmcd
    ianmcd
    15 Aug 2010
    15,288
    Thanks Received:
    5,360
    Lanarkshire
    Country:
    please do not do this cowboy repair, find the cause of the pressure drop and sort it, leak sealer is absolute crap and will do nothing except damage your boiler , anyone advising you to use this is not an experienced Heating engineer
    • Like Like x 2
  6. Sorry Ian, I meant to say that is can be done, but it's a last resort, and the leak should be found first. Thanks for correcting my ommision.
    • Thanks Thanks x 1
  7. ianmcd
    ianmcd
    15 Aug 2010
    15,288
    Thanks Received:
    5,360
    Lanarkshire
    Country:
    @Doggit I never meant at any time that you were a cowboy, was just saying that this course is not the way to do it,have seen so many boilers completely ruined by leak sealer being added
    • Like Like x 1
  8. AGAS
    AGAS
    21 Feb 2014
    9,693
    Thanks Received:
    1,707
    down south
    Country:
    If I can find the photos I'll show you what leak sealer does , I've seen less blockages in an old people's home. Hate the stuff, especially when you're the one trying to remove it .
    • Like Like x 2
  9. Sponsored Links
  10. Nige F
    Nige F
    28 Jun 2005
    20,369
    Thanks Received:
    1,561
    Country:
    Look forward to the pics. AGAS. Though the old folks image just put me off my porridge:censored:
    • Like Like x 2
  11. Don't worry Ian, I never took it that way; it's just nice to get a polite correction when you don't get everything straight first time. There are those on here that will rip you to bits though if you make the slightest mistake, but I've never taken you to be one.
    • Thanks Thanks x 1
  12. Nige F
    Nige F
    28 Jun 2005
    20,369
    Thanks Received:
    1,561
    Country:
    Who could you mean, Doggit. Irrespective of what you say I have a lot of respect for you when you "put your head over the parapet " re: Aspergers.
    • Thanks Thanks x 1
    • Like Like x 1
  13. Agile
    Agile
    26 Jun 2004
    63,570
    Thanks Received:
    4,517
    London
    Country:
    Nice to see polite discussion for a change!
    I would never advise leak sealer on a CH system.
    Some have found it to work on car engines though!
  14. DaveHerns
    DaveHerns
    11 Nov 2009
    2,583
    Thanks Received:
    207
    Country:
    And some have found leak sealant to block their car's cooling system.....
  15. AGAS
    AGAS
    21 Feb 2014
    9,693
    Thanks Received:
    1,707
    down south
    Country:
    Leak sealant is shyte where ever it's put ,
    It's not fixing the problem but covering the problem, so the fault is still there and maybe just delaying the fault again but only worse to fix next time ;)
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
