How to remove connector block cover?
If there is no fixing screw, then put a large screwdriver under one edge and hoik the cover off.
It will probably break, but given the reviews for the product, that seems inevitable anyway.
http://www.amazon.co.uk/review/RSY149D4LYYJA/[/QUOTE]
Thanks - There are 4 lugs that require a lot of force to pull apart and the plastic is thin enough to feel like its going to break. I've added a photo in case anyone else wants to know how to do it ...
Not sure you was meant to just pull it off, usually you unhook the legs with a small flat screwdriver as you lightly pull the cover.
Thats assuming you can access the rear where the legs protrude to do so.
Looks like you can access two of them and i assume the cover will hinge up and maybe then release the other two
