How to remove old cast iron soil pipe?
15 Jun 2009
Merseyside
could anyone advise how to remove remnants of old soil pipe? I am in the process of renewing the section coming into the toilet. So far I have removed a section of cast iron back to a collar, the problem is there are remnants of the now removed section within the collar which i just can't shift. Is this stuff secured with some sort of putty? I'm wondering whether heat may shift it i.e. a blow lamp or paint stripping gun, bit scared of shattering the collar if i use too much force :confused:
Any advice would be great as I am absolutely pulling my hair out now!!
most likely it is lead run
they can be a bit of a pain to get out make sure u you dont let any chunks fall down the waste
as bingo says, make sure no bits go down the pipe, so for starters put a few carrier bags together and place in pipe nice and tight, then get a hammer and cold chisel and break the left over pipe straight into the joint (parallel with the spigot), when through the pipe in one place move a couple of inches further round and chisel straight in again, this will remove a small section of the circumference, it should now be easy to remove the rest by chiselling across from 1st cut, once the cast is out chisel through the rope and lead to completely remove everything
kirk,bingo
is this what my old tradesman called the "leeed soojhur"
to the rest of the uk a lead soldier!!!!!!!!!!!!!!
Thanks for the advice guys, managed to shift the old remnants with a cold chisel as suggested. Don't want to be doing that again any time soon!
Thanks again
