Is there a way to remove plasterboard inside window and door reveals without damaging the angle bead and then needing to re-skim the whole internal window face wall in each room?
If the angle bead gets damaged because the plasterboard reveal has to be fully removed, can both be replace and blended back onto the face wall with the full wall skimmed?
This is to change windows that have straps that fix to the inner cavity wall.
