How to remove tv aerial port
D
DIYHOW?!
Hey! I’m wanting to hide this aerial as it’s not in use. What is the easiest/ safest way to do this? The plug socket is also not in use so thinking of just covering with a blank plate? It’s right in the middle of the wall and I’m wanting to hang a picture above it which I suppose will also hide it but the aerial port casing is too chunky.
Thank you :)
A bit of a lash up but if you don't plan to use it again, take the socket off and cut it back as far as you can see. I don't think it should have been wired like that anyway - probably dangerous.
Edit: On second thoughts, does it come via the socket or is it under the wallpaper?
The feed for the socket could come from above so you need to make sure you don't whack the hook nail through the cable.
That looks like two cables coming on the surface, from below?
The TV one should contain no voltage worth worrying about, even if some kind of amp is somewhere in the system.
The mains may well be a diy Spur?
