How to replace 2 way dimmer switch for 2 way regular switch
14 Nov 2013
London
Hi Guys,
I would like to replace my old dimmer 2 gang 2-way switch for a 2 gang 2-way regular MK switch.
Could you please advise with the wiring?
Many thanks,
Rod
The new switch is an MK Logic Plus K4872 WHI
https://www.mkelectric.com/en-gb/Products/WD/logicplus/plateswitches/10AMPflush/Pages/K4872.aspx
Keep the wiring in each switch module separate from the other: Do not mix up!
On the RH switch, put the wires in C on the old switch into COM (terminal 4) on the new switch.
Put the wire in L1 on the old switch into terminal 1 on the new switch.
Similarly with the left hand switch: C to COM, L1 to 1 and L2 to 2.
What is wrong with the red in the C terminal?
Thank you for your comments.
So it should look like this?
Something went wrong with the flash and I photoshopped the red in terminal C.
