How to replace monarch windows handle and rail
13 May 2014
Hertfordshire
Does anyone know how to replace this handle?
I am unable to find any screw holes to remove this and this is the key (maybe can identify the brand)?
Master lock maybe.
Will have to open to find one screw under?
I found it, it’s called monarch handle.
Problems is that I will need a couple of replacement but doubt I will find it
Ok, anyone know what next in order to remove this?
Can’t see any screws to remove ‍♂️
Just spot another issue while open the window
The plastic bit which hold the screw of the bottom of the window had broken.
Is this just a standard rail? Can I just get the broken plastic parts to change it?
No you don't buy parts, you need a new friction hinge, a pair really, it's a 90s window so bits are starting to break, blown glass next
