We have a Crabtree CU (split load with RCD and SB6000 MCBSs). We have had issues with certain high powered items intermittently tripping the RCD on different circuits. ie a compressor in the garage.. Fridge on the downstairs ring main and more recently a spur that goes outside for a hot tub. All installed before we moved in and the spur to the hottub is 6mm SWA cable and appears to be bonded correctly. My question is - should you be able to reset the RCD with the MCBs switched to on? The only way I can ever reset it is to either turn off the main switch, reset the rcd and then turn back on, or switch each one of the RCD MCBS off and then turn them back on individually. It doesn't trip again for a while doing this and can last for a month or so. Cheers. Andy.
