In my first year, the room had a couple of 13A sockets that were metered. And a 2A socket or two off the lighting - not metered.
Of course, I had a four way lead with 2A plug on - but I knew how to manage the load. The local Woolies sold lots of 2A plugs, and there was a trade selling them on to the next lot of freshers.
It was "a few" decades ago now. I recall it took ages to boil a mug of water. We also had very hard water - I recall in my third year, we had a kettle so scaled up that lumps would flake off the element and end up in the bottom of your mug.
So I bought some descaler, which seemed very slow working. I thought it might work faster if warmed up. It did, a lot , but fortunately I'd stood the kettle in the sink before switching it on
I had a 12V 100W heater which would take at least 20 mins with the engine running above tickover - but volt drop in the harness was significant on the vehicle I was using- and a 240V (defunct ages ago when someone didn't think to unplug it after use) which took about 10-15 mins
Not much. Say 3kW for a minute, that's 3/60 kWH, or 0.05kWH. Work that out as a fraction of your battery capacity/range, and that's (roughly) your lost range.
But, if you are marginal then it could be the difference between needing a splash-n-go charge or not during a journey.
A colleague has a tale of a friend who bought some flashy model of EV - but wouldn't allow passengers to have the radio on during his weekly commute - it made the difference between getting there or needing to stop for a charge
I used to prep my cup at one place of work and heat it on the way to the park where I'd stop for my lunch en-route to the next place, I'd eat my food until it boiled then take the drink with me as I walked the mile perimeter path.
It worked well enough for my situation but not used since, I was recently having a bit of a sort out and came across the tool bag I used for that duty
With the few tools required and behind the centre flap was the folder with 'my copies' of the last weeks work on that duty from 1993.
Complete with part jars of coffee, sugar, instant milk & mug.
