How would you tackle floor issue?
16 Nov 2026
We had an old window and wall removed and this has left us with a line of bricks a fair bit higher than current floor.
We are ripping up the old laminate floor and laying a new flooring as soon as possible.
How can we make this floor good to be able to lay some new laminate floor upto the door.
Chipping brick away by hand to old floor height and self leveling or levelling old floor with brick line.
Trying to keep fairly easy DIY wise and not make a massive mess.
Take the top brick out. It shouldn’t be there. Then fill back up level to sub floor with a compound like Ardex an , fball 1200 and granno chips with a visqueen sheet up the doorframe
So you think its best to use something like a hammer drill and take that brick out. Then fill is as you suggest. trying to make as little mess as possible.
The mortar should be fairly soft around the bricks so a club hammer and bolster should suffice. Then fit a dpc, bed of mortar and joist in that order so the whole thing is at or just below the level of the prepared floor
So good progress for me today. Bricks removed and nothing broken.
So do I need to take time to clear out all the broken bits of brick , mortar etc before I fill it in ?
With some of the raised bits of old floor I should I hack them down as best I can before filling the gap ?
The visqueen sheet should basically go between the new door and new mortar?
I mix up the fball 1200 and granno chips fill up to 5mm below old floor level.
Later on I use the Ardex an to top up to old floor level and level out to old floor ?
Hack these raised bits down with something
Yeah take loose bits out. Fill in with visqeen sheet so no damp can get in through the bricks. You don’t need to buy different screeds. Just buy 1200pro or Bostik advanced or Ardex Na or Mapei NA
Finding it difficult to find any local places selling this stuff.
Would this work
Sika Sikafloor 360
As part of the hole is nearly 100mm should I do it in two phases?
Wait 24 hours and pour some more
What area do you live in. You be better with a bag & bottle mix . Better to have a moisture tolerant screed
