How's this washer called?
Kitchen carcasses can usually be removed and put back again. Access hole for isolator or put it behind the kick boards.
Corner cabinet with granite worktop: no thanks!
Apparently regulations say "where practicable".
1. The regulations (R15.21) state that "Where an outside tap is being installed in a new location, a double check valve (Type EC or ED) should be provided and fixed inside the envelope of the thermal insulation of a building".
2. The "where practicable" bit only applies to the replacement of an existing outside tap.
I'm replacing what's already there, so no need to dismantle the kitchen.
